Hello All, I just sold my 87 sea ray (100 hp) and am looking for something with a bit more power. So I’ve checked out a checkmate in my neck of the woods several times, and I’m looking to pull the trigger, but wanted to check in with some knowledgeable folks first as the boat has an issue or two with the engine.
The boat itself is a very clean 1979 18 foot Eluder. Great lines- very sleek looking.
On the back is a 1987 Mercury Black Max 175 HP V-6 2 Stroke.
The engine has 2 issues- overheating, and running rough.
Issue #1- Overheating. The owner states the boat overheats on anything above idle. This in indicated by the thermometer on the dash. Owner states he “never” ran it into the red, but who knows. To fix this issue, he has replaced impeller, water pump, Poppet? valve, and thermostats. Boat reads 15 psi of water pressure at idle and 30 psi when the throttle is advanced. Water is exiting the pee tube in the back.
Owner states previous owner had the thermostats (both of them?) removed.
Issue #2- rough start, idles decent, won’t accelerate past 1500 rpm. To me, it sounds like it’s missing on 1 or more cylinders. Previous owner has changed plugs, cleaned carbs, installed new engine wiring harness, new starter, new solenoid, new battery, compression on each cylinder is right around 130. Are there any common issues with this engine? Perhaps in need of a stator or something else?
Thanks a lot for the help, just trying to decide if this is the right one or if this is a project to pass on.
