Had a question about checking the resistance on my stator. At room temp, the resistance meets spec perfectly. However if I check it after running the motor the resistance is much higher and well above the acceptable range. Does this mean the stator is bad? I understand resistance goes up with heat, but didn't know if it was supposed to remain in the acceptable range when hot or if it was normal for it rise above? Thanks in advance for any insight on this.
