dizzyspots
Just resealed the lower unit after watching several videos from www.dangarmarine.com.
So the unit is back together, using a manual vacuum/pressure pump and the gear oil filler fitting, in the upper hole.
When I use the pump to add pressure or pull a vacuum, it takes lots off pumping (literal;y 100 + strokes to get the gauge to move, I can get it to move perhaps 1/8 "?
It holds the pressure and the vacuum.
If I simply kink the hose, I can pump it up in a 3-4 strokes, so the pump is working...why would it take so long to develop pressure or vacuum, is it the volume of space that I am trying to fill or evacuate?
Thanks in advance Mike
