Any ideas?
I just picked up a boat with a 70 hp mercury 3 cylinder in which one cylinder has no compresson. I got the boat CHEAP and am hoping to fix the engine as cheaply as possible. The previous owner found out it was only running on two cylinders, after owning it briefly, and rebuilt the carbs.
I took a compression check and got the following: #1: 120 psi, #2: 110 psi, #3: 0, then 15 psi. after squirting oil in the cylinder. I would like to get this thing going without a complete overhaul, but am prepared to do so, if necessary.
My questions are:
1. If #3 has stuck rings, any chance of freeing them? If so, what product?
2. What is the likely cause for such a condition?
3. If the engine needs an overhaul, approximately how much in parts, assuming boring one cylinder, and a new piston. I plan to re-use as much of the old parts as possible.
Any help and direction in this project would be greatly appreciated.
My questions are:
