greasemonkeyjmj
i have a 1987 48 spl with 3 hours on it after a engine rebuild, compression is 145 on both cylinders, rebuilt carbs, fresh gas, carbs are opening fully and timing is advancing fully. the engine actually has a 74 model big gear case lower unit on it, an is ran on a 24 foot pontoon. when i bought it, they were running a aluminum 3 blade 13 3/4 x 15 prop. and no tach. This could of had something to do with the burnt pistons that i replace. i added a tach and it shows 650 at idle in the water in gear , but only jumps up to 2800 at WOT in gear. i decided to change pitch so i bought a 13 7/8 x 9 hydrus pontoon and workboat prop and installed it, the boat still only turns up to 3500 rpm. i also installed a brand new tach and rectifier just in case either was faulty. I am running out of ideas on how to get it where it needs to be, does anyone else have any ?
