Hi everyone I have a 1986 mariner 45 serial # A987331 that has carb issues. the carbs have the economizer jet and there are no baffles in the carbs. This motor has always seemed to run on the rich side and i have never seen a chalky colored surface gap plug come out of it. They are always a dark gray color. I will have to pull a carb off to see if the main jets are .057 for where i live but will it hurt the engine if i run .055 main jets in it to lean up the mixture. can i run it without the baffles or do i need to make some? this is going to be a long process but I would like to have it running right by next spring crappie season. In my opinion those baffles should have been a solid casting of the carb instead of sheet metal. Thanks everyone I am more used to working on diesel engines.
