I have not been able to identify how to remove the lower unit on my 1986 Johnson 150. Specifically, I haven't been able to figure out how to detach the shift linkage.
Backing up a bit, I need to replace the steering arm that has rusted away. I appears the shift linkage goes through the steering shaft. Is this correct? If this isn't right, then please send some advice.
Darn, I can't upload the image from the book because of an error. I'll try to upload that to a reply post, showing "c" as the "shift rod screw" which is identified as the thing that must be removed in order to remove the lower unit.
The other photos are of my engine, and I simply can't figure out where the "shift rod screw" is located.
Any help? Also, do I have to remove the lower unit in order to replace the steering assembly?
