I'm new to this forum and would appreciate any input or suggestions.
I just purchased a 1986 Grady White with a 5.7 liter engine and Cobra sterndrive. The boat came to me with the positive cable of 500 CCA combined starter / deep cycle battery connected to the #1 terminal of a Guest battery switch and the positive cable of a 650 CCA deep cycle battery connected to the #2 terminal of the Guest battery switch with a feeder line running to the accessory 40 amp breaker. The negative cables from both batteries run to the engine block ground.
The Guest battery switch has the following four settings: 1, 2, OFF, BOTH
The previous owner said to always set the battery switch to BOTH for starting and leave it there while running. Does the BOTH setting combine the amperage of both batteries to the starter?
The starter worked great a few times but now will no longer turn the engine over, it tries to but only gets about a 1/4 revolution and stops, I assume, when the cylinder compression gets too great. After attempting to start the engine a couple of times and holding the key in the start position for 3 - 4 seconds each time the wires at the starter solenoid are a too hot to touch.
Does this mean that the starter is burned out and could it have been caused by leaving the battery switch in the BOTH setting?
Thanks in advance for any thoughts.
