It will plane out but then start to bog out shortly after. After I stop and idle for a few seconds it will take off and bog down again, the want to go but bog down again. I've cleaned the carb, changed fuel lines, tank, fuel tank, spark plugs and still can't get it figured out. Compression is low but within 2 psi.... Is the compression a bigger problem than I'm treating it? Or do you think the issue is elsewhere. Thank you for your input
e20crlcdc - rope start
