I bought Full Power Plus water pump kit PN 432955 from Marine Pump and Part Corp via Amazon. The kit came with no instructions or illustrations. There is a O ring of approx 1 3/8" outer diameter and I am not sure where it goes. It looks like it could fit under the top of the impeller housing as there is a slight recess about the same size as the O ring. Does that sound correct? If not where does it belong?
I tried to attach a pic of the o ring sitting inside the underside of the housing but I was unable to do so.
Secondly, the kit did not come with a O ring for the top of the drive shaft. I know I can make a trip to a boat dealer for it but I have many O rings on hand and if I can get the OD/ID/cross section diameter and material type I might be able to use what I have on hand. Does anyone know what the O ring size is?
Thanks for your help!
