Looking for some guidance please. My Little 10hp outboard actually runs and idles great, usually cranks right up on first pull. The issue is when I’m at full throttle on the water after about 30 seconds the motor will die out. I can crank it right back up and it’ll do it again. Thinking something may be going on with the compression and fuel pump, I checked the compression yesterday with the motor hot and throttle opened up and I’m only getting 70 psi per cylinder. I have no water in the oil or anything like that but could it still be a blown head gasket or do y’all think the rings are worn?
