Good evening.
I've got a problem with water intrusion into the top cylinder (only) on my 3 cylinder Mercury. Yesterday i had it out on the water and it started fine, putzed away from the boat launch fine, ran perfectly for two miles up the lake at probably 2/3 throttle, and then I throttled back to troll and it suddenly wouldn't idle. Getting it back was a pain, but once it managed to get past 2500 rpms or so it ran fine again all the way back to the landing, where it repeated its 'no low rpms' performance for a crowd while I tried to maneuver in to dock.
I have good compression in all 3 cylinders, but the top cylinder isn't firing and fouls the plug in no time. No scoring in the cylinder, fortunately. I didn't overheat it that I'm aware of (new water pump last summer, lots of flow through the telltale, and it's warm but not hot) but I figured maybe head gasket anyway. But I pulled off the cover on the spark plug side and apparently rather than a head that's just the cover to some sort of water jacket thing that I wasn't anticipating, lol. So before I started stripping my motor down, I figured I'd beg on here for some advice.
Pros:
1) While I had that cover off, I checked and didn't see any cracks or holes in the cylinder ?tops? where water could be leaking from
2) There was no fuel/oil residue in there either
3) No scoring, holes, or other damage to the cylinder wall or piston that I can see
4) Compression, spark, and fuel supply all are good; the bottom 2 cylinders run like champs.
5) I'm mechanically inclined and have been wrenching for years (just not on outboards)
Cons:
1) Water is definitely getting into the top cylinder; grey-white sludge on the plug is a dead giveaway. Switched the plugs around and tried again with it on the muffs to make 100% sure, and it fouled the top plug again
2) Motor does not have the head-block-gasket setup I was expecting, so I'm in uncharted waters here
3) I have no idea where else water could be infiltrating that cylinder from
4) I am not a Meatloaf fan, so as far as I'm concerned 2 out of 3 IS bad.
Can I get an assist? Does this motor have a head gasket (or even a head?) If so, where would I find them to check them? Also, where else could water be getting into this cylinder from? Is there a water jacket on the crank /carb side too, for some reason?
Pros:
Cons:
