1984 Mercury 35hp shift mix-up
BobArch
I recently got this 1984 Mercury running for a guy. 35hp. I put in a few new parts and had to replace the throttle control. So now the engine is running good, but R is forward and F is reverse. I know I had it in neutral when I hooked the cable on. Any thoughts or ideas on this would be appreciated.
It's a mercury controller, 8 pin 2 cable controller. It's just a simple push key to choke....it fit right into the motor. I had it in neutral when I hooked it up. I don't understand how the gears can be mixed up. Any ideas at all? Because I'm stumped and could sure use some advice. Thanks
Some of those Merc control boxes were setup to shift assbackwards for some 9.8 and 20 hp Mercs--I owned a few. If so, the internal cam can be changed to a more 'normal' on, or you could get another box. The assbackwards ones are getting harder to find.
Jeff
