1984 johnson 90hp v4 Running issues....
nums
Hello, I have a 1984 johnson 90hp v4 (J90TLCRD) that has running issues.
The issues: at cold starts it has a hell of a time idling. I usually have to put it in high neutral and rev a few times to get it to idle. This Usually takes a few tries reving then bog out, reving then bog out then finally idles. Then when leaving the dog if I don't give it enough has reversing it may cut out and I'll have to start it and give it more gas to keep it running. Once out of the lake I'm able to get it on plane and do about 32 mph in a 1703 spectrum. Engine sounds smooth full throttle. When you give it some throttle it will sound like it may die or misfire(rarely) but sounds off.
Preferred outcome:
Figure out why that lower pull doesn't show much wear and have it run a bit smoother after warming up. Any guidance would be great, I do not have a manual for this outboard
Took the new plugs out after running it at different speeds for about an hour. The bottom left looking at the cylinders seems to have no sign of actually firing. All the other plugs have signs of running
120 psi in all 4 cylinders
New champion plugs
Rebuilt and cleaned carbs
new fuel lines
Cleaned fuel filter
Have spark at all 4 cylinders while cranking
(Facing the cylinders)
Left:
255ohms B/Y & B wires to stator
Plug wire to ground
Top: 251 ohm
Bottom: 246ohm
Orange wire to ground
Top: .5ohm
Bottom: .4ohm
Right:
245ohms B/W & B/B wires to stator
Did not test coils since this is not the side I'm having issues with.
Spark plug photos
What fuel pump is on this motor ?----VRO or pump mounted directly on the intake manifold?----Explain what a ---" lower pull " ---is on this motor.-----Checked flywheel key ?
Pardon the spelling errors, went to go edit it and it will not let me.
Dog was supposed to be dock
Lower pull should be lower plug
Meant lower plug, it seems it didn't really have much wear like the rest of the plugs. I believe it has a fuel pump mounted next to carb on right side when looking at carbs
I added photos of the fuel pump in the imgur post
Was the compression test done yesterday or last season ?-----What fuel pump is on this motor ?----VRO or something else????----Does spark jump a gap of 7/16" on all leads , yes , no or no idea why that is an important question ?
I want to say it has a diaphragm style fuel pump. I believe it is pictured in the ones I posted in imgur. VRO has been deleted on this motor
Here is the photo of the fuel pump.
I just checked compression yesterday. Not sure about spark jumping gap.
Started it with muffs the other day and it was popping a lot and wouldn't idle. It would run for a second then pop a few times then It would shut down. Just replaced the gaskets/diaphragm in the fuel pump
So all my coils jump a 7/16 gap except for the cylinder that looked like it didn't fire. It has spark but weaker. I got new plug wires and a coil on the way. Would a symptom of this be back firing? Getting a lot of popping
