I put a voltmeter in the dash years ago, and recently have seen low voltage numbers compared to the past. I checked the regulator / /rectifier in diode check mode on my meter, and the two yellow wires show no continuity to ground either direction. My question is can I put the 35 amp regulator / rectifier in with my old stator? The stator puts out 20 + VAC at idle, so I think its ok.
