I was given a 1984 Johnson 3 cyl. outboard, 70 HP model J70TLCRD. I was told it had been rebuilt, but hadn't been run since the rebuild, a few years ago.(the motor has been painted, and the compression has improved since I've got it sort of running) I replaced one ignition coil, and have spark on all 3 cyl. now. Cleaned the carbs, replaced the internal gaskets, did not replace needle valves or floats. Floats are level. Compression on cylinders from top to bottom are 100, 102, and 110. Test done dry with carbs held open.
It starts with difficulty, then runs rough, surges, backfires at idle. The carb jets are not adjustable. Anyone have any advise?
