I've got an 84 Johnson 35hp that seems not to want to pick up fuel. The fuel pump is pumping, the bowl is full, and the bulb stays hard. I put a complete overhaul kit in the carb including welch plugs. It has 121 & 122 psi compression. The float jet is not stopped up. I can feel a vacuum on the carb when i cover with my hand and it pulls gas thru then. It ran fine last year, after going thru the carb and replacing the reeds (1 was cracked). I'm racking my brain on this one....any ideas?
