Hi all , I have a 1983 v6 merc australia serial number 6220433, my problem is once i go over 3900rpm the engine bogs down, once i give it more throttle it gets worse and sometimes cuts out. Runs perfect below 4000rpm's. This is what I have replaced thus far...new stator, 2 x power pack's, plug's and leads, ignition coils x 6, trigger switch and serviced fuel pump, set the timing a per specs and double checked, clean fuel, new fuel lines and primer bulb, compression test are cylinder 1,2,3,5,6 between 117 and 119 and cylinder 4 110psi.
carby's all seem clear but haven't serviced them as yet, i don't have a problem with a powerhead rebuild but would like to know if anyone else had this problem before carrying on diagnosing.
Any help would be greatly appreciated as I've gone this far.
