83 block and heads, 89ignition, 88 175 exhaust housing because it was originally a 1988 175
Motor runs but is hard to start and has misfire.
Compression numbers:
1: 95
2: 100
3: 100
4: 90
5: 95
6: 100
I had the heads off and the pistons have carbon buildup but the cylinder wall didn’t have any scratches. 1 piston looks different than the others like it has been replaced.
I pulled the plugs after high idle and reving a bit and #6 is dry and black, all the other ones look wet.
Carburetors cleaned meticulously and checked three times. No shared flywheel key. I have 170 V at each power pack orange wire using DVA adapter. New coils. Rebuilt dual fuel pumps. New fuel lines and primer bulb. I drained the tank as much as I could by using a fuel pump and filled with 10gal of premix.
Racerron suggested I look at crankcase compression in a previous post but I am not sure how to do that.
Can’t get too idle or run smooth.
could it be jetted to rich? High speed jet is 56c which is correct for a 150, I could see that the exhaust might have an impact on performance, but not sure that it would cause a cylinder to misfire.
At this point, I also can’t tell if the cylinder is mostly firing and dropping out or mostly missing and firing every once in a while. I am not sure how to test that.
Any help is appreciated. I am willing to pull the powerhead apart if that will solve things. Everyone is telling me to give up and just move on, but I have a hard time with that, it also doesn’t change the fact that these engines ran well at some point so just blaming old technology is sort of wimpy in my opinion.
1: 95
2: 100
3: 100
4: 90
5: 95
6: 100
