81_chapparral_194
ok I have a 1981 evinrude 90 hp e90tlcm after running a couple hours with no noticeable problems the BIG ugly monster shows his head. it will start bogging down as if starving for gas, I went back to pump the primer bulb and it was soft so I squeezed it and when I squeezed it it didn't fill back up but stayed flat. after removing the gas cap (under deck tank) thinking I had a clogged vent it made no difference. bulb still flat, so I kept messing with the bulb squeezing and shaking until finally the engine died. it seemed that as soon as it died the bulb filled back up. (coincidence????) so I primed the carbs back up and fired it back up. just loaded on trailer as to not get stranded on the lake. I had this same problem a couple weeks ago so I changed fuel lines from tank all the way to the carbs, including under the cowling too, EVERY fuel line., but this didn't fix it. ok to give some insight I know its not a vent issue, nor an anti siphon valve because it doesn't have an anti siphon valve. and I removed the cap while starving for fuel. I replaced fuel line but NOT bulb as the bulb seemed fine. any suggestions appreciated. also the tank shouldn't have any trash clogging the pick up tube as I just put the tank in the boat, (running on very first tank of gas in new tank) and checked to make sure there was no trash in the new tank. I was even careful to not let the foil seal from oil jug get into the tank.
