1981 80hp Merc Water coming out around spark plug
When you're replacing the gasket, be sure to smear lots of silicone around the plug hole on both sides of the gasket. Then wait overnight for a good cure before firing it up.
Jeff
Only use silicone if using a non OEM gasket. The newer OEM and some aftermarket are a blackish/green color and are silicone impregnated and use no sealer. Adding sealer will make them not seal.
