Yup, got that. Looking at parts listing on here for 82..it shows rectifier used on all engines, regulator (not reg/rect as on 89) used on power TnT models only. Is there a way to test stator off motor. I have the 89 stator, it looks a bit blackend, but shows 1.3 ohms resistance. OR, can the 82 stator be used with the 89 reg/rectifier? Big difference in price between replacing the 82 vs the 89 units. In short, can I rip off whats there, replace the fried 89 reg/rect with a new one, and if still not charging (should, 82 stator on there shows 30 vac at idle), re-install the 89 stator?
Or, go back to the solar panel, and install a tiny tach? Or, look for a good 150hp? Found an 87 150 merc, on a 16' sidewinder for $1,000. Just don't need the sidewinder, that's what the 115 is on.
