Bought a 1979 ranger bass boat with a 1979 mercury black max 150hp v6 motor.
main symptom is not wanting to rev up to full rpm. Boat won’t plane out. Doesn’t happen every time but when it does, pulling back to idle causes the engine to die. Then starter solenoid won’t lift teeth. Have to manually lift teeth once, then will fire.
the idle seems a little rough and the not coming up to full rpm seems to happen after extended idle time.
I cleaned and inspected all carbs. No evidence of trash, jets clear, no evidence of water, butterflies all sinked together, floats seems to work, needles clean. Reeds show no damage or evidence of heat (checked without removing them. Just visual inspect while carbs off)
cant find a fuel adjustment screw. Only a mention of an air bleed screw in the manual. Haven’t adjusted that in any way yet.
fuel was brand new, can of sea foam run after initial test on lake. Problem persisted intermittently. Replaced two spark plugs (all they had that day).
where should I look now?
fuel pump? Enricher valve? Adjustment of some kind? Stator?
any tests/suggestions/direction would be greatly appreciated.
thanks in advance
s/n for motor 6181979
150hp
mercury black max outboard
1979 year
v6
thanks in advance
150hp
1979 year
v6
