rubberpanman
I've been toying around with this motor for a while now with no experience and I've almost got it where I want it. My issue now is the carburetor. At first it wasn't getting gas so I took it apart and cleaned it. Then gas was pouring out I replaced the one needle. So now after tinkering with it the top carb leaks and the bottom two I can't even tell if they are getting gas. The motor runs so I'm guessing their getting gas or it would shut off right? The flat head on the bottom is old and I can't get it loose to clean. When I pump the bulb it does not get hard you just see gas start dripping from the carb. What does it sound like I need to do?
