1976 omc steering cable
oldstyle
Trying to help a neighbor, he has a 1976 fiberform with an OMC outdrive. The steering cable has broken down at the large ball fitting that goes through the transom. This boat has dual controls. I have searched the net and not found any thing close except one that had a loose cable that would wrap around a drum?? Any source of information that you could point me to would be appreciated. Bruce
That old "over-under" push-pull cable is obsolete. some of the helm parts are still stocked, but not cables. I think Teleflex sells a conversion (but $700+ last I heard) and I'm not sure about dual station.
SO used cable would be good to look for.
The part number is on the sheath of the cable at each end- get the # and google/ebay/pray
after that, you're converting to hydraulic or something - or maybe a good fabricating shop can make something to fix your cable.
no cables avail from BRP anymore:
54 0171910 CABLE ASSEMBLY,10' to. LAST 2 DIGITS INDICATE CABLE LENGTH IN FEET 0
Not Available
0171950 0171950 CABLE ASSEMBLY,50' 0
Not Available
55 0172002 CABLE ASSY,Dual station,22' 0
Not Available
55 0172003 CABLE ASSY,Dual station,10' 0
Not Available
55 0172004 CABLE ASSY,Dual station,12' 0
Not Available
55 0172005 CABLE ASSY,Dual station,14' 0
Not Available
55 0172006 CABLE ASSY,Dual station,16' 0
Not Available
55 0172007 CABLE ASSY,Dual station,18' 0
Not Available
55 0172008 CABLE ASSY,Dual station,20' 0
Not Available
54
0171910
Not Available
0171950
0171950
CABLE ASSEMBLY,50'
Not Available
55
0172002
Not Available
55
0172003
Not Available
55
0172004
Not Available
55
0172005
Not Available
55
0172006
Not Available
55
0172007
Not Available
55
0172008
Not Available
Thanx for the info, I will check the cable for a number and suggest he get off his wallet. Bruce
An excellent opportunity to convert to hydraulic steering. Holy cow what a difference! I bought all the stuff to do it for cheap on ebay.
