Hi Everybody, I have a 1973 Johnson 50hp 50ESL73R. After many years of great service, the motor started running rough and was really hard to start. After much help from Marine Engine, this forum, and my Clymer manual, I decided the gooey substance on top of the block was coming from the stator. I performed some troubleshooting as stated in the manual and confirmed the stator was bad. Since I tend to ride many miles from home along the ICW and various creeks, I decided I would go ahead and replace every major electrical component on the engine. Of course before proceeding, I validated the engine was still producing good compression. Both cylinders have about 140psig. To date, I have replaced the stator (CDI), timer sensor (CDI), Power Pack (OEM), rectifier (CDI), starter (ARCO), solenoid (ARCO), both coils (OEM), both spark plugs (Champion QL77JC4 gapped to 0.040) and a fresh Group 24 625CCA 90Amp-hr battery. Much to my dismay, when I turned the key, the motor happily turned over but did not fire. I checked for spark to validate the 7/16" gap jump and did not find any. I disconnected the safety from the Power Pack and tried again without success. I then went straight to the stator and checked the output with my AMM. I connected the AMM to the brown wire and engine ground (off the Power Pack). While turning the motor over, the AMM showed about 50VAC. I am puzzled. The flywheel is clean. The magnets look good (no cracks). I was thinking perhaps weak magnets, but several threads on here suggest that's not a possibility. Any help identifying a solution will be most appreciated.
