ChipperStrauss
I would like help with testing the trigger on my 650 3 cyl. I can't seem to locate any spex (like an ohms resistance value) to tell me if the trigger is good. The only way one can tell is if it causes the coil to spark. I have a CDI Electronics aftermarket switch box. I can manually spark the coil following the instructions for the switch box. When I hook up the trigger to the switch box and crank the engine, no spark from the coil. I now have 3 pre owned distributors. One of the triggers should work. It seems unlikely that all 3 triggers would be bad. It would be terrific if I could test the trigger prior to rebuilding the distributor with a different trigger. The wires themselves visually look good and are pliable. I could test the resistance of the wires but that would require using a needle probe because the distributor ends are molded in the housing.
Should the trigger fire by just spinning the gear by hand to simulate cranking? This would imply a rotation speed requirement for the trigger to work. It seems that if there is power going to the trigger, which I have verified, turning the distributor by hand should cause the trigger to send the correct signal to the switch. I have no safety tilt switch. The rectifier is not hooked up to the stater. I am trying to isolate the problem by taking as much out of the equation as possible. I did get a DVA spec from technical support of CDI Electronics which I have yet to do because it requires putting almost everything back together again. But, I can spark the coil which usually means the switch box is good.
I was hoping to get my boat on the water by July 4th to watch the fireworks. But, barring a miracle, that is not going to happen.
Any help appreciated to trouble shoot this issue.
