abcjoyride
Hello,
Been having electrical issues. Spark is intermittent strong. Fat blue spark sometimes. Mostly thin white spark across tester. Causing motor to run like it's dropping cylinders and missing. Can anyone tell me what the reading on my seira coil shld be when I put ohm meter on for both primary and secondary?
What I've checked
Battery=good fully charged, connection clean and tight,
Compression=150-170 across all 3 cylinders
Tested plug wires= good, plugs are new.
I've inspected and cleaned both parts to dizzy cap, rotor,
points set properly as per service manual.
Anti rev spring set properly
Fuel pump reconditioned, carbs synced, jets clean, floats set.
What I've checked
