brickmaster587
1957 evinrude 5.5, stuck roll pin in water pump shaft.
Water pump is bad, have a new one but the roll pin in the end of the shaft that holds the spring is stuck and will not come out.
Have tried 3/32, and 1/16 roll pin punches, and both have broken in half and the pin has not moved, was only able to get it flush with the shaft using a hammer.
Need advice, motor runs fine besides water pump.
