Hey all, I'm new here...
To get started I just bought a little John boat that I completely redid. It came with a 1982 18hp 2 stroke mercury.
I was searching the only serial number I could find and it says that it's a 25hp.
So I searched about that and found that my motor can be turned into a 25hp by changing the carb and the exhaust. It said the carb number was bc1c for the 25hp and that's what's on this motor.
To the point... I changed all of the gaskets on the carb and replaced what seemed to be fuel lines because they looked horrible. I can get the motor to run for a minute or two at full throttle but the motor doesn't run like it's at full throttle. After that minute or two it dies and won't start again unless I remove the spark plugs and dry them off.
Then it does the same thing again.
What's the issue here?
