jonboy2542
This forum has been very helpful lately so I have come back for another problem.
I will start from the top,
I replaced the stator recently, along with that I replaced the rectifier since I was informed that it would be better to replace with the stator. Now before replacing the stator it would somewhat idle. I decided to check the carbs after a rebuild and I have the floats adjusted wrong. I now have them adjusted per the manual (float height is level with gasket with carb inverted) I can start the motor and it will shut off after a few seconds. I can push the key in and the rpms will raise but it would still shut off, just longer till it does. What could be the issue? The carbs have been rebuilt and cleaned throughly. Its strange the it idled before
