150 Johnson will not idle
Boogiedog
I have a 2000 Johnson 150 HP Ocean Pro. Runs fine when first started. Runs fine at cruising speed. It starts to miss, cough, and shuts off after returned to idle speed once engine is hot.
Any suggestions appreciated.
The float bowls are plastic.----They are known to warp.-----And have you changed out the water pump impeller ?
Did you ever figure out what was wrong I have the same problem.
This thread is 2 years old and since the OP was a new member and never responded to any of the replies I'd say it's a safe guess he won't return and post an update. It's best to start your own thread, include the model # of your engine, and post full details of what the engine is doing and what troubleshooting you've already performed.
