fisherman9985
I have a 1995 150 HP Johnson Model # J150ELEOM. Just recently I had the boat professionally rewired and gauges replaced as well. Before having the boat rewired, the Tach worked for a while and then one day it just stopped working. I replaced the Tach and at idle it would register 1000 RPMS and when you accelerate, the reading goes to 0. I replaced the tach again thinking that I was a bad one and still the same issue. The voltage gauge is reading 12V with the engine not running, and 12.3 V while running which has led me to believe that the rectifier/regulator is defective. Before all this began, I was having problems with the motor overheating. Compression is 95,98,108, 110,110,105. Before I just go out and buy a new rectifier/regulator, any advise would be greatly appreciated.
