1993 Evinrude 225
I have checked the switch wiring over and over again, I have a spare harness and switch, same thing.
I have 12V to the primer wire when the switch is in Run without the key being pressed in.
I have checked both switches with the multi meter and there is zero continuity across the pins when the key is not pressed, and zero ohms resistance when pressed, so the switches are OK.
How can I have 12V constant to the primer ?
Thanks for reading.
Ash
Thanks for reading.
Ash
