Hello,
So im told i have a 1978 model of above titled engine.
I sunk the boat at the beach a few weeks ago, didnt go fully under as we were close to shore. I got the boat home and dry and got the engine fired up and rinsed out the sea water, it ran a little rough, and i put it down to maybe sea water in the fuel.
a week later i tried to fire her up and was getting nothing, id have a few false fires where the starter cog drops out, but it would not fire.
I tested for spark and was getting nothing on all 4 plugs ( brand new plugs)
So i disconnected the the Kill wire (black/yellow) and to my surprise the motor fired right up.
It now seems that the earth and black/yellow wires, at the key switch, are shorted when the key is in the on/start position. if i disconnect the black/yellow wire from the ignition key switch, the motor will fire and run... then while running if i touch the black/yellow to the terminal on the key switch, the motor will stop.
I found this schematic which is identical to how my engine and remote are set up, but i cant find the actual "engine kill switch" that is on the drawing.
If i disconnect the big red plug, the short at the key switch wires goes.
If i disconnect the plugs going to the CDi units, the short at the key swich wires goes
Ive cleaned the ignition key switch out and tested the terminals and it works as it should
Im at a loss as to how to test the cdi units. im thinking that as the motor runs with the black/yellow disconnected that all the electronics are working fine..
Apart from splitting the harness and checking each wire for damage im at a loss...
Any tips or advice will be greatly recieved
