Just purchased 07 290 Everglades. Got a good deal because the boat wasn't in the best shape and i'm currently working out the kinks. Had an inspection when I purchased for the loan and inspector mentioned Port motor wouldn't turn over 4,900 RPM. He did a compression test and everything came back good. About 3 days into using the boat at idle I got an alarm. It is a long intermittent beep. When I turn the engine off and restart its gone, but will eventually come back at idle, does not come back when running. From what I have read on the forms this seems to point to the 02 sensor. I replaced the O2 sensor with a new Honda 02 sensor 35655-XY3-013. (Motors are 07 BF225s), went out this past weekend and got the alarm on port motor again. Was just floating in the river tied up with a friend and I always like to keep one motor running so I turned the port motor off to get rid of the beep and left the starboard one running and after about 20 mins it now rang the alarm. Please help!
Side note: I haven't been paying attention to which light comes on when this alarm takes place, but for some reason I feel like the battery light might be coming on. When i'm out this weekend I will pay more attention to which light comes on.
Lastly: I read chawl_man's pulling dault codes article, so I did this tonight on both motors and got the same from each; the MIL light blinks. I'm assuming this is one blink, just repeating itself. From the code charts this gives me the following:
- Disconnected Oxygen sensor connector (this cant be it i know the sensor is connected)
- Short or open circuit in oxygen sensor wire (don't think this is it as the 02 sensor is brand new)
- Faulty oxygen sensor (don't think this is it as it is a brand new sensor)
- spark plug misfire (don't think this is it as the first thing I did after buying the boat is have it serviced and they replaced the spark plugs, they did say the plugs the pulled out looked like they hadn't been changed in a long time, but not sure this matters since they put new ones in)
Thanks in advance. After I figure out these alarms my next mission is to figure out why the port motor won't turn over 5K RPMs (think it has something to due with fuel delivery as I sucked by water separator dry and stalled the engine last weekend, after re-priming the filter it ran fine again)
Motors only have 515 hours
