PhatFireMan
My '06 BF-225 is acting up, but running fine as far as I can tell. Looking for a little advice on which direction to go with it...
I ran it out to the Islands couple days ago, 18 miles, no problem. As soon as I came to a stop and idled for a couple minutes...the "check engine" red light came on steady and I got an intermittent beeping alarm. Indicative of an over-heating alarm from my experience, but a good pee stream at the time. Shut it down right away, checked it but found nothing blocking the intake, started it back up, good pee stream, no alarm. Ran it up to cruising speed right away, no issues. About 10 minutes later I was at idle again while setting the anchor, same problem came up. Shut it down, started it up, no more alarm. Happened about 5 more times during the overnight fishing trip, but only at idle every time. Good pee stream every time the alarm happened, although I did notice once when the alarm sounded...the pee stream suddenly became stronger just before I shut it down? Ran back to the harbor without a hiccup. Even able to cruise through the no-wake zone in the marina without an alarm, but again that is just above idle.
I did the impeller last Fall, only maybe 20 hours put on it since then. Motor has 380 hours on it right now. PSI gauge showing 0 while at idle, which it always has. Pressure comes up right away as you throttle up. Showing 20-25 at cruising speed, which is 4250-4500 RPM. Which I seem to think is normal range based on my experience with it. So...doesn't seem to have a water pressure issue as far as I can tell.
I have a new impeller kit in the garage that I can throw at it, but I am thinking that is not the problem. After talking with a few knowledgeable folks I have been told it may be a bad/stuck thermostat, or maybe a bad temp sensor...? Another friend had a very similar problem with his '03 BF-225, and it was a sensor. Looking in the manual the two thermostats look easy enough to change out, but I'm at a loss as far as the sensor. I have an OBD-II code reader...is there an interface somewhere on this motor?
I also heard there was a thermostat housing corrosion recall somewhere around '03-'04 maybe? I bought the boat almost two years ago and was told the motor was an '06, but a Honda tech from another forum told me that based on my serial numbers the motor is actually an '03...?
The motor did come with an '06 manual.
Here are my serial numbers:
Frame #BAGJ1401807
Block #BEAGJ-1102240
Any thoughts? Any help is GREATLY appreciated.
Thanks,
Kris
Frame #BAGJ1401807
Thanks,
Kris
