xtriggerman
Well, I bought this motor, saw it run in a water barrel. "seemed" to start & run OK despite not knowing jack about outboards on my part. Once I got it home and looked it over, I see where some one had written 112, 114, 114 right near the plugs. So After looking things up, Honda says new, they should be 199psi but I dont know if who ever tested it had the throttle open when they did. Cold, the engine barely idled but barked strong with a throttle push. Hoping they is no issue there but on to the main question. Bought a Tester kit to eval all that.
First off, I can see where the ground to battery cable goes but I have no idea about that cut white wire that I have the red arrow on. It has a twisted on red jumper with ring connector as pictured. And just where does the positive cable from the battery go? The power trim ran good at the testing but I cant get power to it without knowing the above answers. The motor's hanging loose on the totally rebuilt transom now since with it down on the trailer roller, no way can I bolt it flat on the transom.
Next up is the controller wires that go to the dash are another unknown. It looks like there are 3 gauges that go to the pictured ends. Can anyone tell me what they are and where I can get a set of gauges that will be direct plug ins? Also, the control cables are like 8 feet too long. Can they be shortened or new ones ordered?
Thanks for any help you folks can offer.
