foodwatch2003
"I would try to find the age o
"I would try to find the age of the bell housing based on whether or not it is the original and match by using a 318 from that period. If the transmission and bell housing are original, I would use the boat's year and match it that way. You can also buy pdf engine manuals on line and download immediately and look at the drawings to make sure it matches. From the reading you have an older 318 bell housing with the starter toward the bottom. I'm sure there is someone here that has the same vintage and can give you a specific part number.
DO NOT PURCHASE FROM A NON MARINE VENDOR as the starter will not have the spark surpression requirements for use in the bilge."
