no they’re not threadedAre the holes in the pin threaded seems to me you get some larger bolts and it pushes right out?
Boot
This is an AQ series drive shaft bellows.
Maybe a shim
Definitely a shim
Yes, that is one of what we commonly see as multiple shims.
I’m guessing to get to the PDS I’ll have to take those bolts out?
DO NOT remove those bolts.
But aren’t we at the back of the engine at this point?
See my images in my previous post.
This is the water neck fitting above.
Be sure that you replace it and the special beaded gasket underneath it.
I have a drive manual in iBooks
OEM..... not Seloc or Clymers!
You can check the lower bearing has the proper shim with a pair of calipers. Press in on the bearing an measure the height ov the bearing to the mating surface. The put the shim in the intermediate housing and measure to the top of the mating surface you want about .004” preload on the bearing.
Thanks Ricardo! This brief explanation is MUCH clearer than the instructions in the OEM manual(s)...For a bit more accuracy and ease;
Over-shim between the Intermediate housing "bore" ...etc...
