Progator135
have you loosened any fittings at the cylinder and briefly powered the motor up to see if any fluid is spurting out - (carefully) on the "down" line? Should be the top one.. If the reservoir is full, motor is spinning and nothing is coming out then theres something screwed up or bypassing in the pump. Or the line is plugged.
Or try disconnecting the all lines at the cylinder and manually move cylinder up and down and check for binding. Just brainstorming ideas....
