I have just re-powered my Sea Ray with a "take out" engine, transom assy and drive (even the throtle/cables, harness and instrument panel!). This engine (5.7 vortec/ Alpha 1 gen2) is like new and the boat it came out of was damaged so I bought the whole package. They incuded everything and they cut the transom off the boat so I was the one that took it apart, all the serial numbers match.
The install went well, transom assy bolted up no problem, engine went, in no problem, just to get things close, I matched the measurement off of my old engine mounts to the new engine mounts and the alingement tool went right in! The problem that I have now is that the drive starts to go on, Splines are engaged cause I can turn the engine with the prop, but just prior to mating up with the shift linkage (yes it is in forward), the drive stops. there is about a 1" gap between the mating surfaces and when you try to take it back off, it's stuck and you have to pry it off the housing. I thought it might be the oring was holding it on the gimbal bearing so I took that off to try it and the same problem. Re-checked the alingment tool and it goes right into the coupler. I'm out of ideas, anyone have any sugestions?
