"ive managed to find a pic of
"ive managed to find a pic of the cdi / coil unit
the gray / black goes to the distrib,the blue is power into the cdi box,the black is ground and the gray is coil,and this is how its been wire.
i have chopped the blue power in and wired it dirctly to the posative on the battery also done the same with the blue into the distributor so thair is no voltage drop on cranking.
also wired earth / ground directly to motor& cdi unit from neg on battery ,but still no spark
thair is 12 volts coming out of the distibutor on the terminal that supplys the cdi ,ie volt meter on output side of distrib,turn motor slowly clockwise,volt meter cuts in / out as the rotar segments pass the amplifier in the distrib.
all thoughts advice welcome
thanks
Steve"
