Hello all I'm having trouble figuring out how to remove the lower unit on a 70hp to install a new water pump. I have shifted the motor into reverse and was looking to find the pin that needs removed to free the linkage to the lower unit. Im pretty sure I've located the pin but I do not see any bolt head to remove the pin. The port side of the motor behind the vro i can clearly see a pin but no bolt head and the starboard side it so tight its hard to tell but it doesn't look like there is a bolt head either it sort of looks jagged almost like its been sheared off but its hard to tell... any input would be greatly appreciated! Thanks.
