Now i have to do a link and sync , my problem Is my SELOC and CLYMER manual are both pretty vague, does anyone know of a video or a more detailed method is located?
also would your method with the w.o.t timing work with idle?
yea that makes sense , I just wanted to get everything good to go, lake isnt the closest and I read you shouldn't get the idle with the muffs on because there is no back pressure otherwise I would do it that way
ok so I tried setting the idle time by just cranking I have my idle screw completely bottomed out and still have to go back always yet , also I've been reading your cam follower should not be in constant contact but it appears that is how mine is constructed see attached photos, maybe I should just set the idle screw half way and adjust the cam followed accordingly and hope I can get the timing right on the lake with the idle screw
so when the cam is at the scribe mark the file timing should be right on
