MFS 9.8A3 Will NOT stay in neutral, will go into forward on its own.
Backstory - I had the lower unit apart, to replace a leaking prop shaft seal and the impeller. While it was apart, replaced upper water pipe seal, gaskets/seals/o-rings under water pump, o-ring inside prop shaft housing, I think that was it.
Now, when running, it will not stay in neutral, wants to go in forward on its own. If you hold the shift lever, on the backside of neutral (towards reverse) it will stay in neutral. Let go, into forward it goes.
I turned the "knuckle" on the shift lever rod, both in and out, to no avail.
What did I do wrong? Did I miss something? Too tight, too loose?
