My 1979 Evinrude 55 hp outboard engine will throttle up to about half throttle and then start bogging down. If the choke is activated it will then gladly run full speed when advanced to full throttle. It revs up nicely when not in gear. Overhauling the carburetors did not help. I'm using different fuel tank and fuel line than the previous owner. I found out the previous owner had the same problem but never discovered the benefit of using the choke. Why isn't the engine getting enough fuel to run up to full speed?
