When starting up this season, we had no water coming out the pilot hole.
Opened up and replaced impeller. Afterwards there was no change. We use a "clamp" over the water intake, connectet to the water hose. When enine is running, water comes out of multiple holes around on the lower housing!
Seems the pump is making pressure outside of the waterpump housing?? What could be causing this? And if anyone has a drawing with item or part numbers on it, that would be great!
By the way, i have blown air through the pilot hole canal and there is no obstruction causing it not to pee.
