"I have a 35 hp 1977 Johnson S
"I have a 35 hp 1977 Johnson Seahorse. I recently rebuilt the lower unit. The used lower unit housing that I put on has some chipping paint. Do I need to install some zinc on the cavitation plate to prevent corrosion? Where is the best place to install Zinc in this situation? I use the boat in salt and fresh water. It is not stored in the water, it is trailered and kept on the trailer... We always flush with fresh water after using in the salt water. Do I need Zinc if it is not stored in the water at a dock? Any help would be much apprecieated on this topic.
Thanks,
Mike"
Thanks,
Mike"
