Rick 16782
Hi,
I'm new to the forum and I have a question about a Hurth ZF630V-1 transmission. We put a new forward gear clutch pack, seal kit and filter in this transmission and before installation in the boat wanted to test it to make sure it worked ok. We attached a 1/2" drill to the input shaft and it seems to work ok and shift properly, but it makes a rotational clunking noise when it's in gear and I'm concerned that the rotational speed of the drill is not sufficient to produce the necessary pressure to fully engage the clutch. The noise sounds like a broken tooth, but all of the teeth were carefully inspected when we tore the transmission down.
Also is there a pressure port in the control assembly that we could use to check the transmission operation?
